After the cooling system has been filled with the vacuum filling unit, another bleeding procedure must be performed for vehicles with an electric coolant pump: Note:
Do not open the sealing cap of the coolant expansion tank during the bleeding procedure.
Switch on the low-beam headlights to perform the bleeding procedure. If the low-beam headlights are not switched on, the ignition (Terminal 15) will switch off automatically after a certain period of time and interrupt the bleeding procedure.
- Connect battery charger.
- Switch the ignition on.
- Switch on low-beam headlight.
- Set heating to maximum temperature. Take back blower to smallest stage.
- Driving experience switch must not be set to ECO PRO!
- Press accelerator pedal for 10 seconds to floor. Engine must not be started.
- The bleeding procedure was started by pressing the accelerator pedal and takes approx. 12 min. (the electrical coolant pump was activated and switches off automatically after approx. 12 min).
- Then adjust filling level in coolant expansion tank to maximum.
- Check cooling system for leaks.
- If the cooling system bleeding has to be performed again, deactivate DME completely (remove ignition key for approx. 3 minutes). Then repeat from point 3.
