Hi
Right time to sort this once and for all!
Symptoms: When accelerating at low revs/ in traffic on a cold start 99% of the time and occasionally when the engine is warm, the car will shake backwards and forwards, almost as if I'm on and off the brake or the clutch. It's quite violent. Then I dip the clutch in and Rev it a little bit and it goes away once you're off on the move
The other (maybe unrelated, maybe related) symptom is that the idle is very lumpy and can sometimes cause the car to shake left and right on tick over, with the revs visably rising up and down for no reason abnormally so
I've replaced - spark plugs, air filter, engine oil, Ccv, vanos solenoids.
I have no fault codes
Can anyone please suggest what this may be as it's ruining an otherwise amazing car!
Thanks in advance
Thanks in advance
:thumbsdown:
