The AI link makes the N52 sound like it'll explode any minute!
Specifically...
Oil Filter Housing Gasket (OFHG): When this gasket fails, it leaks oil directly onto the serpentine belt. The oil degrades the rubber, causing the belt to slip off and get sucked through the front main crank seal into the engine, shredding the oil pickup tube and destroying the engine.
Crankshaft Seal Guard: Install an aftermarket aluminum plate behind the crankshaft pulley. This cheap insurance policy physically blocks a failing accessory belt from entering the front main seal.
"Mickey Mouse" Coolant Flange: The factory plastic fitting on the cylinder head degrades and snaps without warning, causing instant coolant loss. Proactively swap it for an upgraded aluminum flange.
Electric Water Pump & Thermostat: Unlike mechanical pumps, the N52's electric pump fails completely without warning, typically between 80,000 and 100,000 miles. Always replace the water pump and thermostat together to save on identical labour steps.
When looking into an N52 engine bay, what visible signs are there that prevetative maintenace has been done, if any?
I'm building a check list. Please correct any errors/omissions:
1/ Check under and behind the oil filter for any leaks onto the block and down the front onto belt /s below.
2/ Look for a metal disc behind the crankshaft pulley. Is it a common upgrade?
3/ I now know where the coolant flange is - original black plastic, replacement silver metal.
4/ The water pump at the bottom front of the N52 seems inaccessible. Any indications of imminent failure or just replace it anyway if not already done at 100k? I'm guessing not... replace if not done already.
5/ Look for any other leaks from the front of the block.
6/ Valve cover leaks.
7/ Check under car for leaks.
Is that a fair list for engine checks to do when looking at a car to buy?
Roof-wise, I'm aware of required maintenance but I guess wires breaking is impossible to predict.
Reminds me of starting my E46 330ci cab decades ago to drive to dover and down to the south of France. "Boot open" warning on the dash stopped me putting the roof down. Drove all the way roof up (swearing). When I arrived I contacted BMW Emergency Services (they never came) and then found the broken wire by the boot lid hinge. Twisted the ends together... Solved it myself!
