Hiya, I have a 2003 3lt e85, few weeks ago, coolant light came on, no change in temp, went out after work and managed to get 1/2 cup of coolant in , light was off for a few days , and then same happened again. Thought maybe an airlock as was loosing no coolant and never went over temp. Tried few times to bleed system only for light to come back after few days. Light came on, and also engine light one morning going to work, reader said misfire cylinder 3. Got local garage to fit new coil pack while In work, checked coolant again, all good. Stuck in traffic light on and red lined, and engine light back on. Reader said misfire c3and misfire c3 low fuel. Limped car home after cooling and engine sounded terrible. Took to a local Indy, he thinks I’ve cracked the head, even though compression test ok, sniff test ok, loosing no coolant and system seems to be pressurised. Still got misfire on 3, but only when engine hot. Sorry for long story but really need to find the fault, before start throwing money at it, any idea or help would be much appreciated thanks
