My z4 3.0 project thread (lots of pics)
Mitch89 said:
craig3.0 said:
As for th cdv..its the CLUTCH DELAY VALVE.
You can get a modified one of these,or modify it yourself. available from the likes of zeckhausen,which improves/gets rid of the jerky change you can get between 1st/2nd gears.
BMW over-engineered the car with this being fitted,as it cures a problem that doesnt exist/ie makes bad drivers able to change gear,haha.
It causes jerkiness in lower gearchanges,almost making the car die on you inbetween gears at times...SO A MODIFIED CDV IS A GOOD MOD(Basically a blanked off cdv)and easy to install :thumbsup:
I've read on a number of boards that the CDV can simply be removed at the hoses connected directly, without a modified valve. What's the benefit to modding the valve instead of removing it?
A modified valve is only for if you still have a bmw warenty,
ie. still new So personally i would bother putting a modified one back in just connect the hoses back up
^ X2. Done the CDV removal to two different Z's meanwhile and driven over 70,000 km since (the two of them combined): works perfectly fine. :thumbsup:
Some of you may have seen my re-trimmed steering wheel post:
Before:
After:
Fitted crusie-control:
And I picked these up today .... M Sport Seats, Heted/electric/memory:
Fitted with the help of "tdz840" thanks :thumbsup
before:
After:
Love the steering wheel and the seats!!
Have the say the standard seats are very disappointing when you turn into a corner. A slightly younger Hyundai has better lateral support...
This is a complicated area and a minefield of hybrid bio-mechanical vs pure physics formulae exists to prove that this is in fact wholly dependent on the the size and shape of your arse. :rofl:
domsz4 said:
sam1832 said:
domsz4 said:
what do you mean by foam removed from sound generator? what does that do?
Lets more noise from the engine into the cabin,
the foam is just a noise baffle, and with them removed you get a noticbly louder engine sound inside
ah right, where is this bit? i find with my 3.0l i get an annoying sound at certain revs. it really resonates in your ear and can be a little unpleasant. not sure i want more noise but maybe the lack of foam will change it a bit. cheers
If you suddenly get an odd fairly high pitched noise across a specific rev range it sounds like someone has previously removed some foam from your sound generator. I tried this mod after reading about it on here but immediately put the foam back as I didn't like the noise it made (a bit weird and not becoming 3 litres worth of 6 cylinder power imho).
From the engine bay you can pull out the end of the hose nearest the cabin quite easily without undoing anything and look/feel to see if the foam insert is present.
The Zed is too quiet in the engine/air intake/exhaust depts but for me the sound gen mod just wasn't the answer. Now a quad exhaust, maybe that would.....stop it! Stop it! You're making me do it again! :headbang:
Love the steering wheel and the seats!!<br /><br />Have the say the standard seats are very disappointing when you turn into a corner. A slightly younger Hyundai has better lateral support...
Yea the seats are so much better
You can feel they hug your body tighter
Sent from my GT-I9300 using Tapatalk 2
:thumbsup: :rofl:
Today i fitted braided Stainless steel brake hose's, DOT 5.1 Fluid, removed the clutch delay valve and painted the calipers:
Front and back brake hose's:
The set of hose's i bought: http://www.camskill.co.uk/m50b0s4061p84062/_HEL_BRAIDED_BRAKE_LINE_HOSE_KITS_-_HEL_Brake_Line_Kit_-_BMW_Z4_3_0_E85_2003_on_ Im a bit annoyed with really because i assumed this would be all i would need to do the job, after jacking the car up and a bit of messing arround I find out the rear has two sets of hoses for each side. So to do the all the hoses front and back you need 6 hoses where as the kit only has 4
I have sent them an email i will see what happens
CDV:
Brake Claipers ... ASBO orange with black anti-rattle clips lol:
Then I gave it a good clean inside and out and went for a few photos, Products used:
Bilberry wheel Cleaner
Megs gold class shampoo with dodo juice wash mit and two bucket method
Dried with towel
Poor boys black hole
Dodo juice Supernatural
Inside:
Lexol cleaner and conditoner for the leather
Poor boys trim cleaner & dresser
Thanks for looking, all comments welcolm
Mod list:
So far:
Foam Removed From Soundgenerator
Oil, Air and Pollen filters replaced
Diff, Gear box and Engine Oil changed
De-baged
De-french fried
Extiror Trim Restored with G'Technique
Interior Trim wrapped with 3m Vinyl
Replace Aux And Air Con Belts + Tensioner
Dice Installed
TR30 Speed Camera Detector Installed
Re-mapped to 239 BHP and 229 ib/ft
Smoked Head And Tail Lights (lamin-x)
Painted caliipers - Asbo Orange
CDV Removed
Braided Stainless Steel Brake Hose's
DOT 5.1 Fluid
Steering Wheel Re-Trimmed
Retro Fit Cruise Control
Electric Heated Sport Seats
Mods planned:
330 Brake Caliper Up-Grade
Black Kidney Grills (Need Plasti-Dip every where has sold OUT!!)
Front Strut Bar (if anyone is getting rid of one I will take it)
Key Hole Covers (in progress)
Short Shifter (ordered) + M Gear Knob
Detail
are you from essex?
sure i saw you on the A13 yesterday just before i came off at ferry lane. was probably just after 2pm. i was in my 03 grey z4.
ben g said:
are you from essex?
Ha,
I was gonna write on the "spotted" post then i forgot your reg lol
Yes it was me,
Nice motor you have, like the rear lights
cheers. i like your tinted rears, you can hardly see the orange bits at all on the road.
i would've had a play but my petrol gauge said 8 miles left :lol: had to fill up and tescos and come back on the a13 again :(
Lol, Where abouts do you live? i live near southend
Yea thats only the light tint as well, they do a darker one and black out as well lol
i live in chafford hundred.
saw you last week aswell i think at the wickford turn-off (was coming back onto the a13 after i had finished my speed awareness course, saturday at about 12:30pm) lovely lady friend in your car :wink:
My dad lives at chaffard hundread,
Lol yes i rember that too, thats was the A127 wickford junction ... that was my girlfriend :wink: lol
Nice touches on the car love the lamin-x on the lights. Who did your steering wheel?
Excuse my ignorance too but what's the dice mod? I keep seeing it, seemingly relating to audio/ iPod but can't work out what it stands for :(
Thanks very much,
Yea im impressed with the lamin-x I tried doing it with window tinting film first but couldnt do it as it kept creasing and bubling. The lamin-x is cut to shape so it fits near perfect, i only have one small crease that you cant really notice
I got my steering from this guy: http://royalsteeringwheels.com/ highly recomended
The DIce is just a manufacture for an Ipod adapter: http://diceelectronics.com/support/files/bmw_dice_gs.pdf
it basically plugs into the cd changer wireing and allows you to control and listen to your ipod throught the head unit, you get all the track names etc. on the diplay :thumbsup:
