Nosa, ref the steering wheel badge you can go the whole hog and remove the old one as cj10 did or just stick the replacement over the existing one with double sided tape as I and a few others have done. My thinking is if you are in an impact hard enough to trigger the airbags then an extra bit of metal on the steering wheel is the least of your worries, and unless the OEM one is designed to blow to smithereens when airbag goes off, the new one just goes with old one. So it could take you all of 20secs to fit the new one.
