Deepseaskateboard
AnubisZed said:Oddly enough, yes I have thought of thus, as well as a guy in the US and another somewhere in Europe. We all discussed it at some length and the biggest stumbling block is that the control and power for the up and down motor is from the same pcb as the screen, so somehow you'd have to find the correct circuit and then build som sort of new pcb to retain the flip action. We decided it simply wasn't worth it, and assuming that why the Android screen was built to way it was. Someone may come up with ut eventually, you never know.Deepseaskateboard said:Is it possible to do a hybrid of taking the Android screen and hardware and fitting it to the OEM flip up module?
So, removing the oem screen from it’s housing, and then replacing with the android screen and associated electrical gubbins.
I bet you have thought of the same idea, just wondering if it would fit at all?
Personally, for what I use it for anyway, I find the addition of the MMI box enough on a day to day basis.
Hi Dave,
Another question… can you forsee any fitment or coding issues fitting an LCI idrive system to a pre LCI car?
