2 weeks later... final update for now:
As I completed some further sealing I'd missed of the individual sub enclosures I was increasingly finding some emerging issues as ph001 did with buzzing from around the bulkhead with the open top ports. That lead me to try opening up the rear circular enclosure holes again (in combination with the central channel) and for some reason I was now getting good low frequency response from the mostly open system, no buzzing, however quite a lot of booming with the sound bouncing around the boot, including rather anti-social external sound! I'm putting the better frequency response (vs. 'day 1' test) down to a combination of the sealing of the rest of the boxes, putting the boot carpet back in and the Reckhorn drivers loosening up. It seemed the sweet spot (for me anyway) was lying somewhere between the two setups...
As such, I ordered the OE 'soft boxes' and ports for the enclosures which, I'm hypothesising, with the open holes behind them is softening the pressure spikes in the combined enclosures but still giving the subs something to work against. In summary, it's a complex OE systems of chambers, ports and damping giving a mixture of characteristics of both sealed and ported designs, including a high level of interaction between L & R. (As such, it's impossible to do an effective Left vs. Right test)
So far, so good with this setup. No rattling or buzzing but healthy deep bass, particularly in tandem with the powered Focal AS3s up front.
OE soft boxes and grommits (i.e. 'ports') installed:
So, what did I learn...
- With some extra power behind them the Focal 165-AS3s are a big improvement over the OE 6 speaker front setup. With the tweeters set to -3db on the crossovers, and the head unit treble on '+1', this gives the most natural top end. (Comparing to Bose QC35 headphones for reference). Adjust further if required from the head unit.
- The Business CD head unit outputs perfectly reasonable speaker level signals at most volume level: i.e. as long as they aren't expected to drive anything, and avoiding very high volumes, where the bass seems pegged back. As long as your input volume (e.g. phone bluetooth) and amp gain are correctly set, this isn't an issue, and may even save your speakers in extremis.
- A very different sound profile would be ideal for open top vs. closed and town vs. motorway. What works for one is compromised for the other, however the head-unit bass and treble controls actually adjust the sound quite nicely.
- The rear subwoofer enclosure(s) is/are complex! The OE enclosure setup with the reckhorns is working for me
- Never buy a car without upgraded audio (unless it's got an s54)
If I did it again...
- I'd go for the Focal Flax Evo components (c.£500 vs. £170) and ignore the subs for 'phase 1', keeping the 4 channel amp for flexibility. Whilst the Focal AS3s are a big step up over OE, they still don't compare for refinement against my pretty basic and mostly ageing home hifi (sonos amp, wharfedale pacific EVO 20 floor standers (c.2004), MJ acoustics ref.100 sub (c.2007))
