dumaurier7 said:dumaurier7 said:dumaurier7 said:The battery is the first thing I checked, and it was very healthy and still is. This is exactly what I am experiencing..
https://www.youtube.com/watch?v=k8bJegVxo_c
Hello all, I think I may have narrowed the issue down to the main (black) power relay located on the junction box, apparently it was not seated properly! to check the effects of this I pulled it completely out and the car went into CRAZY mode like before which subsided when I reinstalled it, also the running temperature of this relay is a bit warm to the touch, not sure if this is normal so I bought a new replacement just in case to verify.
Nope! not the relay but still definitely seems to be power related. After I changed the relay, all was well for a while, but weird things would keep happening like, lights refusing to turn off, boot not opening with the remote and the aux. port switching off. Simultaneously during the hiatus period, I purchased and installed a P3 gauge which allows me to see battery voltage (among other things) which read normal at the time around 14.2V with the motor at idle. Recently the symptoms have returned and are occurring with a greater frequency as if it's on a timer, so I decide to purchase a brand-new battery just to eliminate it from the suspect list, but this made no difference! two days ago on my way home from work I decided to observe the battery voltage, what I saw was confusing, alarming but relieving! When on the gas the voltage would be 12.5V-12.7V and when I get on the brake it would jump up to 14.2-14.5! Clearly the alternator/regulator is not functioning correctly, and the battery is running things until its power is depleted after which the craziness starts (at least this is what I hope is happening!). I have since bought a new regulator as the alternator only has 22K km on it, so I doubt is physically bad, after I install, I will post my findings again.
Cheers!
The voltages you’ve measured are normal for an e89, they don’t charge at a uniform rate like the older model due to the ibs - it puts more load on the alternator during braking to lessen the parasitic load when accelerating/cruising.
) that this is the final solution!
