Strangely, in 150,000 miles, I never had a OE spring break, and only replaced my OE springs when I put the Bilstein kit on.philbo909 said:Probably can't be worse than the brittle oem ones :?
mmm-five said:Strangely, in 150,000 miles, I never had a OE spring break, and only replaced my OE springs when I put the Bilstein kit on.philbo909 said:Probably can't be worse than the brittle oem ones :?
But some people seem to need them every 40,000 miles![]()
rally-chris said:Mubea is a very well established German spring manufacturer, although I must confess I wasn’t aware they offered coil springs for cars until your post. For all we know they might be the original BMW spring manufacturer!
Chris
MACK said:I'd check if they're variable diameter rear barrel springs you can. When I've been looking some aftermarket replacements are constant diameter and not the variable type which is what you want. In fact some aftermarket suppliers like lesjofors offer both.
