Denis O said:
Taz said:
i didn't realise that but it makes sense
That's because it's not true.
If it is found to be dangerous and fails it cannot be driven away. If it's a non dangerous failure, let's say a rear tail light lens, showing white light, you can drive away.
OK - the rules changed again in February, but in this case OP has a car on SORN and hence no MOT so there are only specific reasons it can be driven
https://www.gov.uk/getting-an-mot/after-the-test
GOV.uk states the following:
Driving a vehicle that’s failed
You can take your vehicle away if your MOT certificate is still valid.
If your MOT has run out you can take your vehicle to:
have the failed defects fixed
a pre-arranged MOT test appointment
In both cases, your vehicle still needs to meet the minimum standards of roadworthiness at all times or you can be fined.
