Hi, I should know this but thought I would seek clarification.
My Coupe is due an MOT in the next month, during the MOT do they merely test the brake efficiency/ performance or do they also check the brake pad thickness too? also I have warped front discs (annoying but I'm putting up with it until I get round to changing discs and pads all round), will they fail a car for having warped discs?
Ideally I would like to change the brakes before the MOT however this weekend is out due to a stag do, next two weekends after that are out dur to Holiday.
One final question regarding MTEC discs which I am considering, I notice that they now come with coatings, whilst the coating is a waste of time on the friction surface does the covering extend to the visible hub area which typically corrodes on standard pads?
Regards
Regards
