More boost Mr Sulu, the results are in..
B21
Elite
 Scottish Borders
So if you want to know in detail what spending over £7k on bigger turbos, bigger exhaust system, bigger inlets, outlets, bigger intercooler, better ignition syste and better LPFP gives you then its about 150 BHP more than a stock 35is and 180nm torque..or put it another way £500 gets you the first 60 BHP and the next 90 BHP costs £6k+..you can all now leave..
For those that stayed..
So my tame tuner Richard aka carabuser on certain forums has with me iterated slowly through 6 revisions of tune..we are now at 20.5 PSI boost on 99 RON fuel, running very sweetly.
Took the car to the dyno guys today (Met with Nanu there)..and we did three sets of runs on V4 (As its called) of Richard's tune..with stock airbox and filter, with a Pipercross foam filter and with the airbox lid off..ie fresh air into the inlets..
The dyno results are on the graph shown, and for reference included the old MHD V10 stage 2+ maps with its best figure (lid off).
So its a 500 bhp 700nm torque engine now (there's is a liitle more tweaking to be done, but we are really as far as this is going to go..that is reliably, forever and with absolutely fabulous driving ability..
The price of discovery is usually high..no regrets..but I think tuning wise, subject to fine details we are done..
Enjoy..
https://youtu.be/o88ldXzhpe4
  • stock vs mhd stage 2+ v10 no airbox or filter subtract 8 bhp and 5 nm for airbox and filter.jpg
Are you posting this multiple times to make sure no-one has a chance to miss it? :? :poke:
Kind of understandable when you've spent that kind of dosh to impress, I suppose! :lol:
I publish specific work packages individually so that anyone looking at that specific subject can look at it in isolation…I add the work to the long running story for continuity and for those who want to see how the story unfolds over time :thumbsup:
I realise it’s rich in content and light on opinion…
I actually like fresh threads for new bits of a project. I have a tendency to skip threads eventually when they become a long list of (well warranted) "well done"s and miss the actual updates.
Nice to see the gains vs cost. Be interested to know the difference in fuel economy in the day to day pottering to the shops etc.
(Oh, and keep up the good work with the thread titles!)
For those interested in how tuning is done …the car is put into manual 3rd gear and rolling at less than 2,000 rpm..it’s then booted at full throttle to the shift point, after the shift the run finishes..the MHD data logging strips out the before and after and gives a window with upto 80 variables that are recorded which then can be analysed after …
Afterwards the logs can be viewed within MHD or a custom viewer in this case Spoolstreet..
I’m showing todays logging which is the 8 th iteration of tune..the strategy to be safe and slowly increment variables to see how the engine responds…every engine is unique albeit with some common traits ..eg on the N54 normally cylinders 5 and 6 are more problematic as the gas flow to them is poorer and the back of the engine is hotter..
I’ve used the reader bar to show some data values…
You can’t graph all variables at one time as the scales get compressed and there’s too much clutter.
So there are several to show different attributes..
I todays run on a different road and I can see the rpm line is not as smooth previous ones as the car was riding less smoothly..
We can see on one chart rpm, called for boost pressure and actual boost pressure..this is a good graph as the real boost pressure is pretty closely tracking the called for once we are underway….at the beginning we have the lag effect of what’s called for and what’s available falls short.
We have a graph showing high pressure fuel flow ..this is a mechanical pump with no speed control ..the good news is we above 1,500 psi all the time we need it..running low could result in melted pistons…
We have a graph showing ignition deviation per cylinder from the planned timing...corrections are common and there’s a trade off between not enough power and too many corrections..note the odd rogue one..
Another graph shows waste gate duty cycle ..100% is waste gate fully closed ..this should only occur when initial boost production…a good rule of thumb is to be at 50% ish when going full chat..showing your turbos are working too hard..
The air intake temperature graph is a function of how good your intercooler is, how hard your turbos are working and how cool the air coming into the intakes are..
In this case we have excellent control…bearing in mind this is in F and we can get upto 300c air temps leaving the turbos if it’s all going bad..
Enjoy..
buzyg said:
8) :thumbsup:
What does it feel like after 5k rpm ?
It just keeps going…previously it was obvious after 5.5k that you were chasing a declining benefit..you can see that on the MHD10 plots..now it keeps on singing..so much that I’ve moved the 3rd 4th gear shifts to 7k..
It’s really really lovely..
The re-mapped gearbox..xHP..with these turbos and the much developed tunes have had great results..
Much smoother..much revier ..well pleased..
B21 said:
buzyg said:
8) :thumbsup:
Enjoy. :D :driving: :thumbsup:
buzyg said:
B21 said:
buzyg said:
8) :thumbsup:
.......for the short period it's not facing the wrong way up a big Oak tree....... :poke: :wink: :evil:
Now that was uncalled for Johnathan! :poke:
Peter lives in Scotland, so more likely to be a Pine tree..........a pine in the arse as it were. :D
I'm not sure he'll have much arse left once it's cartwheeled around the estate..... :o :wink:
Peter will tell you off for being silly in the wrong place. The Lounge is the place for that, not serious threads like this one.
Sorry Peter! :oops:
Sorry Peter! :oops:
:telloff:
I overlaid the best off for stock..MHD V10 stage 2+ and the TTE500s on the same graphs do it’s easier to assimilate the differences…
The stock figure at 347 is better than the book figure of 335 for a 50k mile car with walnut decoke and fresh plugs n filter..so a good basis
The MHD V10 reflects the tuners work on a 12 year old conservative tune by BMW
Our tune with TTE500s shows the results of the best off in terms of products and a steady set of tuning developments over several runs.
The graphs reflect how it feels..
Smooth and slightly better off the line..powerful low range shove, turbine feel through the mid range and a rocket like unceasing charge to the red line..
So apart from cost no downsides…smoother, more powerful, better high end performance….good result
smorris_12 said:
<cough>Tyres</cough>
Solved that..always have a spare set on hot standby… :thumbsup: :tumbleweed: :rofl:
The Sports Conti 7s are probably the top dog tyre..the more power the better they show their advantage :driving:
https://www.evo.co.uk/car-technology/204817/continental-sportcontact-7-vs-rivals-tyre-test-review
If the 460 BHP Mustang likes them I’m sure I’ll rub along fine… :thumbsup:
No sign of any stress on them for me..but of course even fast road work is not like a track day..but I don’t do track days… :tumbleweed:
