Directed at those with pre-facelift E85s with the PITA airbag module system.
I spent a couple of frustrating hours last week in Coventry, trying to code a centre module (SIM85) into a low mileage Alpina. The owner had been told by the main dealer that it couldn't be done and effectively his car was scrap! That's helpful!
He'd managed to procure a matching part number module from @GenZed so I slaved it in and started coding. Only got a little way then failed. so I opened up my box of spares and found another. Same thing. And again with third one. Exactly the same code which would be highly unlikely on all three.
Found slight corrosion inside the plug. Cleaning made no difference. Back to my box and found a length of loom with a good plug on. Soldered that into place.
Tried again and yup, same problem. At this point I'm looking around for the petrol and matches.
Using INPA, we discovered that it couldn't actually read the part number of any of the modules. Out of desperation I plugged the original back in and it could read that, although showing an internal fault.
Then the lightbulb moment! The part number on the module ended '9811'. INPA showed it as '2767' which is the latest compatible version. Whatever compatible module you fit, it will always code to the latest version and display that on INPA.
So, this wasn't the original module fitted. Everyone had 'just assumed' but in fact it had been replaced before.
Looking on Realoem it says 2767 and 9811 are both exchangeable in either direction. It appears this is not the case though. Once it's coded up to 2767 it can't go back. I'm sure in the past I've read of someone else having issues with the 2767 module?
Back to my box yet again, dug out a 2767, plugged it in and it coded with no issues. Airbag light out, customer on the verge of a breakdown, and me very relieved.
So..................... moral of the story for anyone who has read this far:
If you have a failed module and need a replacement, do NOT assume the number on the module is spot on, always use a code reader of some description which will tell you the 'part number' of the software inside the module. Then find a replacement that matches that, or at least ask me or one of the other airbag coders for advice.
