Monoblock - weedkiller
Sae
It's getting closer to summer for most, good weather for driving, bad for the monstrous green growth on driveways and monoblocks.
So looking for help from driveway detailers for suggestions for easily handled, non pet lethal weedkiller.
cheers.
The discussions on this forum are going downhill... :thumbsdown:
:rofl:
... but I would really like to know too! Preferably some I can put on the weeds in the back garden that won't kill the grass :thumbsup: Gardeners help!
Hi i have same problem on my drive and would be very interested in your replys, current method is take one z4 and leave two black lines the length of the drive :D
Greig
Pathclear or Roundup, I prefer to spray directly onto the weeds as they come through but you can go for the whole-drive treatment
Round up or another systemic weed killer would be the best option.
The weeds that grow in block paving generally grow in the kiln dried sand that is used to brush in between the blocks, this sand helps to lock the pavers together tightly. That is why you should replace the kiln dried sand quickly if you jet wash your drive and wash out the original sand. It is rare for the weeds to come from below unless you have had the Cowboys in.
I should point out that I run my own landscape gardening business.
Mechanical is the best way.
Stihl attachment:
Before:
After:
60 seconds with the unit.
Do you own every tool ever possibly needed??
You would make a great neighbour, if you had any that is :thumbsup:
If you're going to use Roundup then get the one where you pump it up and then spray. The ones where you squeeze the trigger get quite tiring after a while.
