Porkers are just as bad. 993, 996, 997 … 991. It must be a German thing.Marlon said:They are BM's so no
Indeed - I struggle to remember the model sequences, however the numbers don't start merging with the engine sizesBusterboo said:Porkers are just as bad. 996, 997 … 991.Marlon said:They are BM's so no
Busterboo said:Is there any logic in E89 model numbers? So, for example, the 30i is 3-litre, but the 35iS isn't 3.5. And so on.
Brilliant.Pbondar said:When I was in marketing we had to cope with this all the time...
You came up with a beautiful and entirely logical strategy usually based on a play on a numerical fact..engine size, clock speed, max take off weight etc..then some tw@t from R+D/ engineering would make a ‘better’ one that completely b^ggared up your grand naming nomenclature...
So, all the marketing department would lock themselves in a room labelled ‘detached from reality’ and come up with a new plan...
Usually then it would go like this...
Take the original reference number..work out how much more or less you wanted to charge for the other versions than use that as a ratio for your numbers, preferably using non linear arithmetic eg factorials, logs, etc
After a few hours with a whiteboard a new strategy would emerge entirely logical to the team but probably entirely unconnected to anyone who didn’t work for the company or was not a groupie..
So in that context the E89 Z4 naming convention is entirely logical....
The 3.0 litre car was regarded as the base line...at the time the 23i was the entry level version...25i was too close so make it a 23i ...simple..
The 35i made sense as a premium car..but then somebody came with the overboost..already used up the m sport monica so let’s add an s to the end 35is ..
Then the techies come up with the N20 engine that pisses all over the bonfire..hmmmh...
So the 30i can’t be eclipse by a mere 4 pot so let’s call it a 28i and nudge the price down a tad to compensate....
The 20i can be much cheaper than the 28i as its slightly ‘brain damaged’ so we charge a lot less..
Still not scraping the floor for an entry level product...we never expect to sell any but it gets punters through the door before we upsell them, strip out all, and I mean all the goodies..demean it with a 18i title and drop the price enough but not too much so most people buy the 20i ..
So it’s all very logical ..simple!![]()
Marlon said::?
Dare I ask you to explain the logic behind the Porsche nomenclature :scratchhead:
