this is getting heated again...
the only difference between a bridgestone runflat and a bridgestone non run flat is the sidewall. Which will be a lot stiffer on the run flat. the tread pattern, tread depth and rubber compound will all be the same.
I would argue that any of tread pattern, tread depth, rubber compound, tyre widths, tyre pressures and wheel alignment all make way more of a difference to how a car feels than the stiffness of the sidewall.
it seems bizarre to me that people happily recommend fitting different width and profile tyres to cars, which will make a huge difference to a cars balance front and rear, yet suggest mixing otherwise identical run flats and non run flat tyres is seen as a sin punishable by death, and you are the scourge of the community.
if you do mix tyres, you wont instantly die in a fireball, but if you are exploring the limits of tyre performance on the road for some reason, be aware that the stiffer sidewalled tyre will respond differently to the softer sidewalled tyre. this is the same if you mix a soft sidewall tyre (like goodyear) with a hard sidewall tyre (like bridgestone), even if they are both non run flats.
