Hoi all,
I am looking for some advise. My Z4 has started misfiring, after doing several tests we've discovered it isn't firing on #3 and is intermittently firing on #5.
We've done compression tests, changed out the coils, changed out the plugs etc etc and the only thing my mechanic could think is that (despite being rare) it's an ECU problem.
We spoke with several ECU specialists and apparently similar faults have been seen in the past, we sent the ECU off to them but they were unable to complete a full test (whatever that means) and returned the ECU to us without charge. My mechanic is still of the opinion it's the ECU, or possibly a fault in the loom itself.
The next (and only?) logical step seems to be take the car to the local stealer but I suspect their solution is going to be buy a brand new ECU and then pay the labour on fitting and pairing the keys etc. I don't know if they can do any testing on the loom but will speak with them later today.
Are there any other steps I can take to test possible causes, I was thinking of maybe trying to locate a local donor ECU to test the possible loom fault, would a donor ECU (and paired keys) start the car, I am assuming there isn't any other logic within the loom that would prevent the car turning over?
Cheers in advance,
Dave
Cheers in advance,
Dave
