misfire
bluespit
 Near Chester
Site Supporter
Nice morning so Z4 out. Missing on one cylinder, engine light on after about 30 seconds.
back into garage and off to work in the daily
any suggestions where to start. was fine when it was put away at the weekend - thinking coil pack or plugs?? will put the scanner on later
thanks
Ok. Just had a quick fiddle. Scanner c110 shows nothing. Don’t trust it. Cheapo scanner shows misfire on 5. Engine light now out and running fine.
Swapped no 5 coil pack to 4 and plug to 3. Erased code. Will run tomorrow and see if I get new code.
Plug looks well eroded but I need to look at others first.
Why is C110 scanner showing nothing! Trying to add photos
I think I'd be changing those plugs out either way, do you know how old they are? Anyway, wait to see if the mis-fire moves is the first thing.
new plugs already ordered, eurocarparts bosch at £9.50 each (minus discount)
any better recommendations?, i can still cancel
Mate, if you were planning on taking them out to look why not just replace :lol:
Bosch, NGK both are fine. If there is an offer on I'd get a spare coil just in case, never hurts to have one in stock.
