Misfire Cylinder 3 & 5
majeric
started the car and at idle the engine was struggling.....then the yellow engine management warning light came on.
turned the car off straight away.....and restarted.....started fine.
plugged in my laptop to find 2 cylinders had been misfiring......and apparently was reported a while ago...although i've never experienced it.
ordered a complete set of coil packs - ended up paying £126 for all 6 including del - Bosche OEM parts from http://www.bmpartsstore.com.
Called Jaime at Sopers and they wanted close to £280 for a set....OUCH!
So, if anyone is after a new set of coil packs.....get them from bmpartsstore!
Will change them this weekend :-) the spark plugs are pretty much new - have had 3k miles on them......hopefully new coil packs will resolve the misfire.
Same thing happened to me. Took it to BMW for an Inspection 2 and the diagnostics stated that there had been a misfire in 1 & 6 cylinder. BMW said this was quite common! Plonkers....
