gwatson said:How raspy is it? I love the idea of a cheeky mod like this, but looking for more volume and bass than rasp.
gwatson said:Sounds good.
Any idea what diameter of pipe they used?
chilistrucker said:gwatson said:Sounds good.
Sorry, no.
But I can find out if you want me too?
Dave 2 dogs said:Chilistrucker
I absolutely flat out refuse to have my radio on , I’m not even sure it works🏎
I’ll not be needing mine on Saturday
chilistrucker said:Right bear with me as I’m useless.
He said 2 inch as that ‘Slides’ in just perfect for the weld.
He said you could go 2 and a 1/4 but would have to drop the exhaust for the welding.
Hope that helps?
gwatson said:chilistrucker said:Right bear with me as I’m useless.
Hope that helps?
Perfect, really appreciate that. I'll take a look online, probably need 50cm i'm guessing...
enuff_zed said:gwatson said:chilistrucker said:Right bear with me as I’m useless.
Hope that helps?
I hope you mean 50 mm?
Unless you're jacking the car up a bit
OK, so re-read it, and maybe you mean 50cm length? In which case I'll bog off![]()
Hope that helps?
flybobbie said:zedwheels why bother splitting the exhaust, i just made up a mock tail pipe on the right.
I'll panic if smoke comes out.greg81 said:Won't that look a bit odd in winter when you've only got smoke coming out one side?
flybobbie said:I'll panic if smoke comes out.greg81 said:Won't that look a bit odd in winter when you've only got smoke coming out one side?
Does anyone care.
