A
Me too!Silverstar said:That doesn't look too minor to me :wink:I for one would be interested to see the end result.
AlienZed said:Ha ha your so complex,me am a simple sole wi simple needs.
Having this fitted tues at halfrauds,that should be fun.
Pbondar said:Decided after much research to do a minor audio upgrade...I’ll let people know how it goes!![]()
hellojohn-e89 said:Pbondar said:Decided after much research to do a minor audio upgrade...I’ll let people know how it goes!![]()
Do those Rockford’s fit straight in the cubby’s behind the seats or do you need to make baffles up?
Pbondar said:hellojohn-e89 said:Pbondar said:Decided after much research to do a minor audio upgrade...I’ll let people know how it goes!![]()
They are for the footwell 6" woofers, the Audison 8" are the sub woofers for behind the seats..
john-e89 said:Pbondar said:hellojohn-e89 said:Do those Rockford’s fit straight in the cubby’s behind the seats or do you need to make baffles up?
Ah ok...do they all fit in with no baffles needed making up? A simple screw in, plug and play job? Im assuming you don’t have the 14 speaker HK system with the 850 watt amp as you have the Alpine amp yes?
Should be good this, interesting thread.
Pbondar said:john-e89 said:Pbondar said:hello
All the speakers except the 6” woofers in the footwell SHOULD be plug n play..the woofers need new connectors and maybe some ‘adjustment’ at the back...
My set up is the common 11 speaker set up..
The mid price range oem amp is replaced by the Audiotechnicia Match 7 that in theory is plug n play..for all bmw mid range setups not the 14 speaker / HK set ups..
Unfortunately the Z4 E89 has a unique channel / setup so it will need the Match harness ‘editing’
The alpine drives the sub wooofers on the external channel of the Match 7
I’m replacing that alpine with a mono amp alpine as a result of discovering the ‘uniqueness ‘ of the Z4 E89 speaker ‘ amp set up..
I’ve run out of channels so either it’s the woofers on one channel or the sub woofers..
I’m assuming 250 watts rms on the subwoofer channel should get the buggers working..
JimsZ said:Wow, I bet that cost a packet... Looks ace though![]()
Im still procrastinating on the door speakers...
Would you recommend going with the Eton B100N or trying something else?
Dru2000D said:How much was all that if you don't mind me asking?! Looks like a seriously interesting swapout for the standard speakers![]()
