Miles Per Tank
Adamski said:
simonlpearce said:
I did wonder about the 'feed me' light. I'm also fairly convinced the fuel needle moves depending on how hard you are driving. I could swear mine goes up and down if I'm booting it with just above the last mark left..
Yes. The gauge adapts to your driving. So if you've been hooning all day and the feed me light comes on, then you switch to miss daisy driving, it's possible to switch the light off again...
Well you learn something every day. I'd noticed this a few times but just thought it was to do with driving on an incline.
That's a surprise to me as well, I thought it was purely triggered by how low the fuel level was?
Regards
I thought as much in regards to the needle, it had me questioning the float at first thinking it was reading faulty or a bit temperamental.
I don't get hung up on the actual number of miles per tank, its more a curiosity thing and i guess the thread will help potential buyers knowing if they can afford to run an M or not :thumbsup:
The gauge can't adapt surely? Isn't it just a sender from the tank? If your driving hard, then it won't be accurate as the fuel will be sloshing about a lot and appear less than there is, then you slow and the sender levels out? Light goes off etc?
I know the range adapts depending on your driving style. I think it looks back at the last 20 miles average or something!
I'm going to disagree, i'm certain it does. Its definitely not anything to do with sloshing about as the needle would be far more erratic and would constantly be up and down. This is way more subtle.
The light comes on when the remaining range hits a figure, around 70 miles from memory, so changing your driving style or roads your on can make the light go, out as your mpg improves so does the range.
thepits said:
Smartbear said:
My 3.0si after a motorway run
Miles to Go?! :o That's a bit tight.
Cough, cough, coast............................ :thumbsdown:
In this day and age it makes no difference. Our fuel tanks are plastic so do not corrode, we have fuel filters to trap any crap and the fuel pickup is near the bottom so regardless of how full or empty your tank is you are going to pick up whatever is being chucked around.
Even with the gauge on 0 miles left I bet there are 5-6 litres left.
I could see the light coming on a different times, but I can't see the gauge needle moving depending on driving style. Happy to be proved wrong though.
Im going to try this theory out if i can. My light just came on so will take a pic, then will drive like a granny and see if i can get it to go off and the needle move up. Honestly im not insane, it does do it :P
The gauge don't move back up until you put fuel in :wink:
Roundozo said:
Fastatv said:
I have read that both fuel tanks are 14.5 gals.....and what I compared was 2006 year models. I also read that the Z4M produces about 330 horsepower as compared to my Z4 3.0I which only makes about 230 horsepower. That's a substantial difference and would also make a very big difference in miles/kilometers per gal. And make the M much more fun to drive as well! :lol:
Is yours a roadster then? I think the 3.0l in the coupe produces 261bhp. the older 3.0l roadster is about 231. The coupe has a 55 ltr tank as well (i think) and the M is 338bhp and also has a 55ltr tank.
Yes, my Z4 is a standard roadster. I rarely get it over 3,000 rpms and when I drive it, its usually on back roads, not a great deal of starting and stopping. I do get on it ever now and then and even tho its the "standard" 3.0I, I'm still amazed how quick this car is and also amazed at the fuel economy it gets. On interstate trips, I always get 30 to 32 mpg, and that's filling the tank and doing the math, but the computer in this particular car indicates the actual mpg very closely to the math I do in figuring the mpg. Anyway, I can hardly imagine the thrill that the "M" must provide......it must be incredible. I certainly want one some day when I can afford it. :thumbsup:
So to srhutch's point, I don't think the needle goes back up either, it's the range changing because it's not how much fuel you have that matters, it's how far it will get you.
Come on guys, think about it. The gauge is measuring how many litres are left. Driving more economically doesn't put fuel back in the tank. However driving more economically can increase the range making the light go out. It happens more on my DD than my ///M as I get 50mpg out of the DD instead of 25mpg out of the ///M, so driving more economically can have more of a dramatic effect.
Happy to be proved wrong, but I 'think' that the gauge reading/needle will vary by range. I've been low on fuel before on a forum run in my 3.0i. The light came on and I slowed right down and took it easy. The needle didnt move for around 40 miles, and the range slightly increased during that time.
I doubt the fuel needle will still operate solely from a float in the tank (do they still use floats in the tank :idunno: )....
So your fuel gauge needle didn't actually go up? It just slowed down its rate of descent-understandable if you had been hooning a bit on a run & then drove for economy :driving:
Regards
i find the guage and miles left are a load of old shite at the low end. today my guage said i had just under 1/4 tank and 47 miles. work is 34 miles and some how after 30 it read ---- and the guage was at zero. i drove another 2 miles to my hospital appt and then another 5 to the petrol station like. 30 quid = ~25l so about half a tank and now the guage is at half.
some how again im 40 miles down on my usual mpg per tank. either im driving more in the wrong gear or its down to it being colder or i have a problem....
your'e never going to get accurate consumption figures by adding "about half a tank" The only dependable/repeatable method is to brim the tank, then note the miles covered when you fill it from empty again and do your calculations from those figures.
regards
