Verinder1984 said:
RedUn said:
Are you in the UK? Our cars only have 1 set of cats... So it won't pass an mot no...
Yes uk z4mr. Hummmm. I think I can fix emissions issue with mot not overly worried. Will it flare up any errors on dash? And with induction would you say it worth remapping.
I noticed with only induction it has flat spots between 1-2k rpm sometimes.
You sure he means the Cats and not the centre x pipe part / resonator? Seen that 'straight' piped before which will give a bit more sound and not cause any issues. Straight up cat delete seems risky these days...not sure how you'll pass an MOT as emissions is all electronically done and recorded isn't it (as in the tester can't just overlook it...)?
You'll need to program out the post cat 02 sensors or you will get an error code I would think.
Can't help with the flat spot but not sure why'd be in that rev range anyway. Putting a lot of load / stress on the engine down in that range potentially, keep it 2k and above would be my advice and if it's fine from there up to the limiter I wouldn't worry about it, it's not a diesel :wink:
See if you are throwing any codes would be my only suggestion if it really bothers you but not unknown for some induction kits to cause some minor running issues on these.
