Yup, I agree, the O-rings in mine were flat, so would not properly seal again.bigwinn said:Again only my experience- the hoses are good but the o-rings inside the pipes fail or would benefit from replacement
Have a look at real oem to get part numbers
https://www.realoem.com/bmw/enUS/select
And, to be honest, that leak has obviously been there a while so it will have spread around a bit. You would probably need to clean it off first and then monitor to see where it starts again from.BumpyZ4 said:There are usually 3 main places where they leak 1. Oil filter housing gasket. 2. Valve cover gasket. 3. Oil sump gasket. There are other places but I would look at those three first.
05_3.0i_zoom said:Pardon my ignorance but I would not find the oring section for the radiator hoses![]()
05_3.0i_zoom said:Oh by the way, I was thinking about using local car wash to clean it with a pressure gun. Yay or Nay?
