No longer required. Used once to change exhaust burble duration and other settings on E89 35is which is now sold.
Bargain £40.
Description below
https://bimmer-connect.com/products/bg-mhdex?utm_source=ShoppingAds&utm_medium=Google&utm_campaign=bg-mhdex&gclid=CjwKCAiA1aiMBhAUEiwACw25MVHyw-k_butD6MzHku6tiH84adnHXx6X-HLk2pep0HK2ruDaUFwdGBoCz_kQAvD_BwE
MHD Flasher Wireless Adapter
E and F series model (orange). Faster than regular KDcan cable. Compatible with F/G models but not as fast as the F/G series black adapter.
The MHD wireless adapter allows you to reliably use all MHD features on the go, faster and easier than ever before. Just plug it in to the OBDII port, pair your mobile device to the Wifi access point created by the adapter, and you can flash, log, read codes etc. instantly - no cable needed anymore.
While using the MHD wireless adapters your phone LTE/4G data connectivity and bluetooth all remain active - and charging the phone is possible.
Adapter are compatible, or will soon be compatible with your favorite other apps - xHP Flashtool, xDelete, THOR - the M Flasher, BimmerGeeks Pro-Tool and many more.
Bargain £40.
Description below
