mfsw fitted
jonnyfive
 Berkshire
Hi all
1st of all a big big thanks to Ben for given me a hand. :thumbsup:
All went well a bit of trouble with the wire chock blocks but got there in the end.
Well until i went to drive home , no indicators or rear lights, some of the interior lights not working and steering wheel on wonky, oh and airbag on.
Got home, took every thing apart again in 0 deg in garage couldn't work out what was wrong every thing seamed in place.
After playing around a bit i found with light switch off , steering wheel controls work airbag light off, switch lights on no steering controls airbag light on no indicators or rear lights.
Scratched head a lot then bingo i noticed i had put the two connectors on the back of the light switch together wrong ,left one was on the right and right one on the left. :roll:
Swapped them around re-aligned the steering wheel so now straight and now every thing works fine . Half hour job turned into a 3 hour job.
So glad i managed to fix it didn't fancy cycling to work tomorrow, so treated my self to KFC ( test drive of course ) just to double check every thing.
2 nd thanks to cj for steering wheel
3 rd thanks to joe at sopers for the free tourch which came in realy handy.
And again cheers Ben
Hi ben
I must admit I thought you can only put the steering wheel on one way but no just pulled off moved it around a few splines and pushed back on and got it spot on first time .
