might be of use!!!
A21 Driver's seat memory
Plug connector overview
X650 12-pin, black Plug connector Driver's seat memory
X1465 15-pin, black Plug connector Driver's seat memory
Pin assignments at plug connector X650
1 Not used
2 A Positive activation Drive, driver's seat backrest angle adjustment Drive, driver's seat backrest angle adjustment
3 A Positive activation Drive, driver's seat height adjustment Drive, driver's seat height adjustment
4 A Positive activation Drive, driver's seat angle adjustment Drive, driver's seat angle adjustment
5 A Positive activation Drive, driver's seat forward/backward adjustment Drive, driver's seat forward/backward adjustment
6 Not used
7 Not used
8 E Negative activation Drive, driver's seat backrest angle adjustment Drive, driver's seat backrest angle adjustment
9 E Negative activation Drive, driver's seat height adjustment Drive, driver's seat height adjustment
10 E Negative activation Drive, driver's seat angle adjustment Drive, driver's seat angle adjustment
11 E Negative activation Drive, driver's seat forward/backward adjustment Drive, driver's seat forward/backward adjustment
12 Not used
Pin assignments at plug connector X1465
1 A Signal Motor, driver's seat upward tilt Drive, driver's seat angle adjustment
2 A Signal Motor, driver's seat downward tilt Drive, driver's seat angle adjustment
3 A Signal Motor, driver's seat sled back Drive, driver's seat forward/backward adjustment
4 A Signal Motor, driver's seat sled forward Drive, driver's seat forward/backward adjustment
5 A Signal Motor, driver's seat height up Drive, driver's seat height adjustment
6 A Ground Ground point
7 A Signal Motor, driver's backrest forward Drive, driver's seat backrest angle adjustment
8 E Terminal 30 LHD: Fuse F29 RHD: Fuse F15
9 E/A K-bus signal K-bus connector
10 A Signal Motor, driver's seat height down Drive, driver's seat height adjustment
11 Not used
12 Not used
13 Not used
14 A Signal Motor, driver's backrest back Drive, driver's seat backrest angle adjustment
15 Not used
