Hi everyone.
Was undertaking a bit of an upgrade to my sound system today, installing the power box amp to my car (basic sound system) ahead of fitting some speakers that are on the way. Fitted it fine, tested it all went well, then disconnected and threaded the cables through the back of the passenger footwell bit where the fuse box sits.
Unfortunately when then trying to start it up following this was met with a Christmas tree of error codes on the dashboard, and it now appears the car is receiving a charge and then turning off and back on again (every second or so). Means that using the code reader is redundant as it’s currently firing off pretty much every single code.
Fortunately after putting the car on a trickle charge I was able to get the roof back up before it rained, I’ve also tried to reset the system by taking the charger off and disconnecting the battery for 15 minutes but no joy in fixing the issues.
My assumption here is that the FRM has failed? Wanted to check in on here first to see if there was anything else I might’ve knocked/loosened that would be causing this, or anything else that I could try to fix it, before sending it off.
Thanks in advance.
Thanks in advance.
