Make it stop PLEASE>>>>
Athos
Ok so my audio system (Nav with DSP) some how has the echo stuck on and no attempts to turn it off seem to work. Does anyone have a solution to reset and or disconnect the DSP and stop the echo, echo echo echo? :headbang:
mr.tourette said:
tried a battery disconnect?
Good first step - disconnecting for 30mins effectively reboots some of the car's systems, including audio & satnav. Not sure if it resets settings on the system though. Though you'll need to re-set one-touch on the windows and the clock.
hahaha nightmare.
you could always just listen to the 'beatles live in hamburg', then it would sound ace. i always thought that album was lacking a bit of 'ambience' / needed a bit more reverb :lol:
good luck fella :thumbsup:
Chris_D said:
hahaha nightmare.
Seriously! Can you imagine dark side of the moon! :rofl:
I had tried that but only for 20 mins...so let me give that a shot and Ill get back to everyone!
J
30 is an arbitrary number, 20 is probably enough... But give it a go anyway !
Ok so I tried a battery disconnect for 3 hours and that did not work. How long do you need to disconnect the battery for to completely clear the system? :cry:
Thanks in advance..
