Dan McNulty
New member
Hello all, last spring I replace my valve cover with new gaskets, aluminum bolts, all genuine bmw parts due to a leal at the rear passenger side of the valve cover.
The valve cover came with a piece that I couldn’t find where to install but it looks like it might be pcv related.
I’ll try to post a picture of it.
Anyway me valve cover is leaking in the exact same place again! I was careful and used all information available on the torque and bolt torque pattern, ive been working on all my vehicles since I was young and have been able to successfully replace the other leaks on this car with no problems, ie oil cooler, oil filter housing, oil pan. Thinking this was pcv related i just sealed up a rubber hose into the hose that exits the rear valve cover and blew thru the hose with a very slight back pressure telling me the pcv valve is working. Spark plugs look to be firing great no carbon on them what else could cause this leak to reappear? TIA Dan
