MAF Sensor location......?
DannyBoy
 South Manchester
Following on from the previous thread about poor fuel econonmy in a 3.0, appears I have been pointed in the direction of the MAF sensor. That is, the MAF sensor should be cleaned every now and then or a poor fuel/air mix may be sent into the engine resulting in crappy MPG.
So, does anyone know where the MAF sensor is on a 3.0 and how to remove it?
Many thanks in advance. :)
Unless your car is "throwing codes" (or you have an over-oiled K&N filter installed) your MAF is probably just fine.
Be very careful on cleaning a MAF. The sensor is very sensitive to contamination.
That being said, cleaning it is cheaper than replacing it. So it is worth a try.
The MAF is plugged into the intake tube going from the air filter to the throttle body. (sorry, don't have a picture of your engine handy)
Here is a description of cleaning the MAFs on a 2000 M5.
http://www.louv.tv/cars/m5/MAF/
I had the same problem with fuel consumption. I found that my upstream O2 sensors were bad, but not throwing a CEL light... read over this post..
http://www.z4-forum.com/forum/viewtopic.php?f=3&t=4488
Oh, after the replacement, I now get 31MPG at 78MPH....
Wswpoleowlde said:
What I read I really liked it. Thank you for your information!
Wswpoleowide, are you looking to become the 'Wikipedia' of the zed? You are liking a lot of information.
