M54 Rocker Cover, Intake Manifold, Sump and Back Box.
Jamie25
 Gloucestershire
The back box came off my E85 3.0. As most of you know the OEM exhausts on these are one peice from the down pipes back. My centre box was blowing so I replaced the system with an aftermarket one. The rear box and hanger looks in okay condition so I cut off the pipes about 600mm in front of the back box.
The Rocker Cover, Intake Manifold and Sump are all from a used M54B30 engine I bought in January last year after flooding my original engine. The engine apparently had circa 74k miles on it and is running nicely in my car.
The rocker cover was slightly different, I think being a slightly newer version than mine to take different coils. See the photos and post numbers below.
The intake manifold I only swapped out as I'd replaced the PVC system on mine a year or so earlier, but this one looks good. The fuel rail is not present.
And the sump I swapped as I changed the gasket, which seemed sensible. I honestly can't recall if this sump was my original or from the newer engine.
I'm looking for £50 for each item, plus delivery cost or local collection. I'm in Dursley, Gloucestershire but I'm regularly in Bristol and Gloucester.
