Hi everyone,
I'm hoping to get some peer confirmation on a sudden, shutting-down issue with my M54B25 engine before I start throwing parts at it. (E85 2004 2.5i)
The Symptoms:
While driving, the car will randomly and abruptly shut down completely. It does not stutter, misfire, or drop into Limp Mode; it feels exactly as if someone pulled the main power plug on the engine computer.(After parking under the 35deg sun for a month without any action.)
- 2806 Cruise control: time limit of data transmission reached
- 27C3 Thermal oil-level sensor
- 28B2 Speed limitation: reset
- 27F8 Pedal position sensor, potentiometer 2
- 2741 Pedal-position sensor 2:
voltage supply
- 27C4 Main relay
- 27C7 Main relay: switching delay
What should I do next?
Before reading the codes, I originally thought these symptoms pointed directly to a failing Crankshaft Position Sensor (CPS), given how common it is for them to cut out when hot and refuse to restart until cooled down.
However, seeing this massive cluster of DME power, pedal sensor, and cruise control codes makes me think it’s strictly an electrical delivery issue feeding the DME itself rather than a sensor position fault.
Does anyone have any extra tips, or is swapping that sky blue relay and unplugging the oil level sensor the absolute best next move? Has anyone seen a bad ground strap cause this exact "switching delay" cascade on an M54?
Any advice on what else I should check while I have the E-box cracked open would be awesome. Thanks!
The Symptoms:
- Sometimes, it will fire right back up after pulling to the side of the road.
- Other times, it refuses to start immediately. It will crank endlessly but won't catch. If I let the car sit and cool down for 5 to 10 minutes, it suddenly fires up completely normally.
- Battery resting (Engine Off): 12.5V
- Alternator output (Engine Running): 13.9V
(The charging system and battery appear healthy)
voltage supply
- 27C4 Main relay
