Player 1 said:
The pedal feel is much more reminiscent of the 911`s and Boxster's I've driven and are a step up in terms of outright capability over the old brakes which themselves weren't bad.
That is exactly what I ended up telling people when I switched to multi-pot fronts. No massive difference in braking force, but the feeling of more stability under braking through the ball of your foot. Porsche brakes seem to be less servo assisted, in general, which isn’t for everybody but is more in keeping with the idea of a sports car.
Pedal was a bit firmer too, but since I changed pads, hoses and re-bled at the same time I switched callipers, I can’t rule out that being due to other factors.
Just be wary of any changes to front/rear braking bias. If you are unable to figure out where you should be on paper (total piston area before/after will give you a rough idea) then a track day or some covert heavy braking will give you a clue!
