M3 E46 Wheels on an E85?
Tcochrane92
Leamington Spa, Warwickshire, UK
Do the E46 M3 wheels fit my 2005 3.0 Z4?
E46 size:
Front: 18 x 8, 47mm offset
Rear: 18 x 9 , 26mm offset
Thanks!
Iirc the fronts are OK
An if you can get another set of fronts they will fit the back ,
Machine monkey did manage it but had to machine them up to fit
I have the 19" wheels not shore on the offsets of each. But they where difficult to fit. I have had to add a little more camber roll my arches and machine 3mm off the mounting face of the wheel. That said they look bloody great on now. Many people just run 4 fronts and that works. If you got the 19" i may possibly swap my fronts for your rears as i have a crazy plan to run a squire set up.
The set I'm looking at are 18"
Does that mean that these wheels aren't a direct replacement for my current 18" z4 ellipsoids?
Tcochrane92 said:
Yes it dose mean that the offsets are still different. M cars have a narrow rear axle compared to non M cars.
Tcochrane92 said:
:headbang:
It has been done BRC on hear has them. I am not sure if he is running a staggered or square set up? Of if the 18s may just fit with running the right size tyres probable best to send him a PM and ask.
E46 size:
Thanks!
Rears are a bit too aggressive for a non-M car but OK on an //M.
They'll only stick out 4mm more than a set of 224s, should be fine if you don't go mad with the tyre sizes.
The 19s are 9.5J ET27 so much more difficult to fit.
