srhutch said:Check the part numbers on realoem.com that will confirm for you.
Yorkie Z said:srhutch said:Check the part numbers on realoem.com that will confirm for you.
Thanks for that. Useful site![]()
Taz said:Yorkie Z said:srhutch said:Check the part numbers on realoem.com that will confirm for you.
did you change the starter? i think mine needs 1 urghhhhhhhhh :thumbsdown:![]()
Yorkie Z said:Yeah I changed the starter motor and the ignition switch. Starter was about £75 and the ignition switch was about £20. Fitted them myself and it was quite easy.![]()
srhutch said:What are your symptoms Pete?
Taz said:Yorkie Z said:Yeah I changed the starter motor and the ignition switch. Starter was about £75 and the ignition switch was about £20. Fitted them myself and it was quite easy.![]()
where did you get a starter for £75?
