Lower cowl is a single torx screw and you need to undo the column locking lever and wriggle it off.
Instrument is a single torz under the top face. Wriggle it out towards the column.
LCM is the light control module which is really just the back of the light switch. Once the cluster is out you can get to the big connector plug on it. Unclip and see if the correct wires are in place. Awkward to reach into with the wheel, so you may as well take it off again for the 10 mins it will take.
