//M Roadster Detailing
Minihen_LDN
 Enfield
Not mine but just came across this one my facebook. Not sure if this a member's car or not but the work done looks amazing.
Will be getting mine done when the weather picks up a bit.
https://www.facebook.com/media/set/?set=a.1329105950438904.1073741876.744275038922001&type=3
Saw this on fb too. Looks great
Keep up the maintenance and wash safely to keep it looking fantastic
It's almost a shame to drive it again !!!
All I do normally is just jet wash using cold water
Don't trust myself to do anymore, but might try those quick detailer sprays in the future
Just use two buckets to wash.
No need to bother with quick detailer unless it needs it.
The wax should keep the dirt loose so a good snow foam then wash with a soft mitt.
None of that wax on wax off technique.
Wipe back and forth rinsing the mitt between upper and lower parts and in between wiping panels
Then pat dry using a plush towel.
YouTube is your friend but get your detailer to show you how to wash it.
That way you learn and you're not throwing good money away detailing your car when you will just ruin his good work.
A handy tip for all.
After washing and spraying off soap with a jet wash. Get a normal hose and run water over the body (don't turn tap on too high)
It will allow sheeting of water making the car easier to dry
si-forks said:
Have you got any pictures for people that don't have Facebook yes there are a few of us still about
Why do you need Facebook? Just click on the link, you don't need an account to look at the pictures :thumbsup:
I'm sure we've seen this detailing job on here before - but it's well worth admiring again - beautiful job.
Just wish there was something of this standard available where I am. Last time I paid a 'professional' to detail the car, they just damaged it :cry:
