///M Cruise Control - Myths & Legends Busted - Retrofit DIY HOW TO!!
srhutch
Right lads, its fitted and working.
Background for those new to this. There has always been talk about not being able to retro fit cruise control onto an ///M. However in recent years a few Indy's have been successful in doing so. Last year I managed to obtain some info from a forum member who had it retrofitted at an Indy and had established that the connection in the ECU that needed to be connected was Pin 4 on plug X60002. The indy wasn't 100% with his comms to me so I need clarification as I didn't want to toast my ECU.
Recently another forum member was keen to get this fitted which spurred me on and with some confirmation on a few point from Scooba_Steve gave me the confidence to dig deeper.
1. Apart from the wire to the ECU, all the other requirements are the same for any other E85/6 that require the loom also to be fitted.
http://www.hutchison.org.uk/z4-forum/CC/CC_retrofit.pdf
I think even routing the wire thrugh to the ECU might be easier. By removing the top of the ECU cover lets light in and you can see a hole in he bottom going through the firewall. Remove the panel below the glovebox (2 screws) and then poke a piece of stiff wire down the hole in the ECU box. Tape the blue wire to the stiff wire under the glovebox and then pull it through into the ECU housing.
2. Connecting the blue wire to the ECU is probably easier than on any other E85/6. I'm including the following for completeness, but isn't required.
Pin 4 X6002 identified in this picture. This required removal and disconnection of ECU. Luckily you don't have to go anywhere near this. For clarity this wire is already fitted in the car.
Now the extra info Scooba_Steve posted mentioned about Pin 4 X6021 and said that he didn't think this went anywhere. So I managed to trace the wire from Pin 4 X6002 back to where I thought it went. I tested for continuity which confirmed this was the correct point.
I then removed the plug which confirmed suspicions that it didn't go anywhere.
So for the time being I used a Positap (Much better than Scotchlocks) to connect the CC loom wire to the wire in Pin 4 X6021
**This is where the wiring diagram says to connect the Cruise Control loom to **
https://www.posi-products.com/posiplug.html
I then fitted the Cruise Control Stalk using a dremel to remove the main section and file to get to finished size.
I then went on to do the final part which turned out to be the hardest. Only because it was like building a ship in a bottle as the loom for the LCM wasn't long enough to pull out of the dash, even after cutting it free from it's location. I used a descent ratchet crimp tool and wouldn't suggest using a cheap £1.00 job otherwise the connections won't be great.
Please ensure you cut the correct wires on the LCM. Best way to to extract the plugs from the connector and trace the wire from the pin locations. There are two yellow/purple coloured wires so be sure you cut the right one.
So all plugged back together and car was fine. The forum member who gave me the info last year reported he had to take his car back for coding as after fitting it didn't work. The Indy confirmed this and said the "Vehicle Order needed to be updated". Now I understand this to be nothing more than a list of options etc fitted to the car, and actually has nothing to do with them working or not.
So today I went to meet up with the South East Hooooooners and can confirm that Cruise Control is working 100% :trampoline: :-D :driving: :happyclap:
I am going to hopefully find a correct male pin connector and re do the blue wire to give a OEM look by using the main block to connect into. I have an old O2 sensor so might canabilise that if the pin is the same size.
As I mentioned to PVR this morning I said I would do today, so was in fact 24 hours early :P
Took me a couple fo hours, but that was with all the diags. I reckon you could do this in under an hour.
pvr said:
2 years was required to find out what cable was purple as he is as blind as a bat :evil:
Yes that reminds me on the LCM there are two yellow/purple wires so be sure you cut the right one. I took the plug to bits to confirm. If I hadn't I'd of cut the wrong one, as at the time I hadnt seen the other wire.
Nice, think I'll have to do this myself :wink:
Better get in quick before the price of the stalk rockets :cry:
Good job Steve :thumbsup:
To mirror OE connections a male pin is needed at X6021. But that just goes to X60002 and I don't *think* it does anything else so it should be possible to join straight there and use the retro pin. Could be tested by simply unplugging I guess.
Good to know it's just the VO coding as that's the same on all the others models.
If you have trouble getting to the LCM loom I find taking steering wheel off and the instrument cluster out gives more space.
It would appear the car is partially wired for CC. The wire from X60002 goes to X6021 and then nowhere as you said. The male connector isn't even there. I need to find out what size the male one is then buy and rewire.
Try unplugging pin 4 at X6021, if there are no dramas (other than new cruise not working) then you can go straight to X60002, is that in the same electronics box in the M?
Pin 4 doesn't connect to anything at x6021 so yes you could. TBH it's easier to connect there than pull the Ecu out though.
Top work Steve, off to buy a cc stick that can sit in my garage for two years before fitting :oops:
BTW Steve you need to update your signature :thumbsup:
Scooba_Steve said:
Where is X60002 on the M? Hard to run the cable to?
I wondered about some of your posts, and can see the confusion now.
The car is already wired up from X60002 Pin 4 to X6021 Pin 4.
The blue lead from the CC loom just needs to connect to it somehere. Where I have connected is the easiest way, but if the correct male pin can be sourced then you could plug into X6021 Pin 4 and have more OEM look.
Done, but run out of room. Might have to construct a JPG with all the info in.
