Doh, I thought it was referring to something more technical behind the dash lol Thanks for the offer but I'll have a look and hopefully give it a go. If you wouldn't mind PM'ing me a contact number or email for if I get stuck that really would great?
Well dans just outside tring as per pastry
And I'm 4 miles or so down the road
Maybe we could make a day of it a little M meet and sort out day?
As where do live hutch?
Great Job,Srhutch/Steve.
Agree with other comments,why people didn't spec this from new is anybody s guess.
Great write up
As for Sopers,excellent service,and the parts Manager is a very helpful and easy guy to talk to.
Sopers have always been good to us on the forum
Long may people on here keep using them
Haha or if you do it pastry I'll come to see you
Only the other side if Aylesbury
Just not read up on it enough between doing brakes and work and sorting garden!
I successfully fitted the cruise control today with more than a little help from Dietcokeman....cheers Bryan
Once we'd got our heads around the instructions earlier in this thread ( cheers srhutch) it was realatively straight forward. Access to run the wire to the ECU was easy via the passenger side footwell and there was already a hole into the ECU compartment. We then cut the pin 4 X6021 wire and instead of using a connector we solder jointed the new cruise control wire to it.
For the light control module connection we first removed the vent/cup holder, then removed the leather trim and then unscrewed the LCM and removed it.
This gave us access to cut the cable tie holding the loom to the column frame allowing us to pull the 54 pin connector into the drivers footwell to work on. With good access we cut the pre installed plugs off that came with the CC loom wiring (not the one that pugs into the stalk obviously) and we stripped a section of the brown/black and violet/yellow wires without cutting them and soldered the new wires onto them and that's the job done. Well apart from cutting the trim panel for the stalk with the dremel.
Thanks again Srhutch for all the info and Dietcokeman for all your time today with this and fitting the M5 illuminated gear knob, amongst other bits, it's much appreciated
