Markcoopers
Don't let them just sit in a cold damp garage, looking in envy at your aftermarket zorst languishing where they once sat, sell to me and I will give them a new lease of life.
As the originator of modded silencers for the Z3M and Z4Ms I've done this job a fair number of times and over a few years. I really can't see the problem that you see. The OEM silencers are stainless steel and if you use stainless wire in a MIG welder with a shielding gas, then your weld should be clean where it matters. The carbon will be on the inside of the boxes, only, and you can only reweld them back together on the outside and therefore shouldn't include any carbon if you clean the outside of the boxes before welding.Markcoopers said:I am reluctant to cut my own up as the cases will be contaminated with carbon and the welds could over a pretty short time corrode through, so havering a spare pair makes a bit of sense
