Lower Steering Trim Panel (useful retrofit cruise control)
wilbo
Active member
 Berkshire
Selling as I sourced a spare one to cut when I recently retrofitted cruise control. It does have a small hole on the left side, from a previous owner, but this will disappear if you were going to retrofit cruise control (as you cut this bit out). The right side has a few scratches which I believe is from a metal keyring, but other than that its in great condition.
Its part 10 on the RealOEM diagram:
http://www.realoem.com/bmw/showparts.do?model=BT52&mospid=47797&btnr=32_1383&hg=32&fg=30
£20 posted.
Hi when u fit the cruise con did u fit the loom also or is yours pre 04?? Im only asking as im doing mine this week and wondered how hard it was and if there are any funnies you came across
My build date is July 04 so had the wiring present so it was really easy to fit. Very easy to whip the bottom trim off with one screw and check if the loom is there.
Fitted my stalk in two minutes..cowel took a little longer to cut neatly...but because mine zed is a pre oct 04 it was soooooo easy...and it really helps on motorway journey's... :)
Sent from my iPad using Tapatalk
