Lower Control Arm Rt Side (passenger) bushing leak
Buddy L
The aft mount for the lower control arm is leaking (a rust colored residue from the leak). Obviously I need to repair/replace. Is a complete LCA replacement in order, or is it common to replace the bushings? If I replace the right side, should I replace the left side?
Car is up on jack stands. And the right front wheel goes in tomorrow for a little work. Someone hit a road hazard and put a slight bend in the wheel. Discount tire found it while replacing right front tire.
I will probably work the rest of the issue while it is up. Iam really excited about this project! :D
Shipkiller said:
Do both sides.
If you go with a better brand than OEM (polyurethane), you will tighten up your front end....
So bushing replacement is an option, rather than the entire lower front control arms?
Unless I get the LCAs off, and there appears to be suspicious wear.
Any suggestions on the "better" brand?
Again, Thanks!!
Check Six!!!
