scootr said:
It sounds like everything I'm reading about it being an ultimate driver's car is true. Lightweight, mid engine, direct steering.
My concern is how raw is it... I'm sure I can ( workout until) I can get in and out but my old bones may not tolerate it if it is jarring at every crack in the road.
What Year/model is that one you have Rob?
Mine was a 2006 elise S with the Toyota 1zz engine (variable valve timing) the R versions used the 2zz engine (variable valve timing & lift) which can rev to around 9k
Owned mine for around 3 years, daily driver for 2 years but then i caved in & bought another car to drive to work.
They’re actually less crashy over bumps than my e85 with sport suspension was, super lightweight at around 850kg (earlier models lighter, later models heavier) so the suspension is surprisingly supple.
Handling is fantastic with probably the best steering feel of any car, can bite if you’re clumsy with it (lift off oversteer)
I spun mine twice in the wet
They can sound tizzy & buzzy due to the aluminium tub chassis having acoustic properties over bumpy roads
Clouting a curb badly can write them off as the double wishbone suspension is mounted directly to the chassis with no “bolt on” section to replace if it’s damaged. I missed the curbs when i span mine
Definitely a car i was proud to own
https://youtu.be/CxflDjfBdoI
