fernando306
My friends,
My Z has 112k on the clock, I bought it with 84k 3 years ago.
It always pulled HARD, seemed like a lot more than the rated 228hp.
But about a few weeks ago, it simply feels like it has lost 50 HP or something. It is as if I have downgraded from 3.0i to the 2.5i engine. Another way to describe it, is as if I can never push the gas pedal all the way down, but just half-way.
Car starts on a dime, runs smooth. Zero oddities. ECU, zero fault codes. The ONLY fault code it has is from the EWS: "33 toleration of changing code increased with key #3". No idea what this is, and if it could interfere with power!? Sort of like a vallet key!?
I should mention: Vanos was rebuilt 20k ago, DISA valve rebuilt and inspected perfect, no vaccum leaks. New air filter and MAF. New ignition coils. Compression measured between 175psi and 185psi across all six cylinders.
What the heck could this be!?
