Hi all,
Latest issue with my facelifted E85 2.0i. The car has been losing oil, with no obvious signs of a leak. I'm topping up around a litre every 10 days (usually do about 20k miles/yr). There is also excessive smoke from the exhaust under acceleration. Took it to my local bmw indy and they've diagnosed that the stem seals need replacing. Apparently even though the part is relatively cheap, this is a laborious job.
The chap also mentioned that the 'eccentric shaft' may likely need to be replaced too. So makes sense to get this done at the same time (if needed). He seemed to think that the part is quite expensive. I've tried looking online but the only thing I can find is Eccentric Shaft sensor. Is that the same thing?
Appreciate that the 2.0i isnt considered the best engine. But wondering if anyone else has had a similar issue?
Regards,
Rick
Regards,
Rick
