Loose piece of metal behind disk
1000rr said:
Took mine off today, as had a rattle too. 2 of the 3 bolt holes had rusted through. Taking it off involves removing the wheel and the disc and hub, but a bolt has seized on the brake caliper, and could I get the bolt out??? No!!! :headbang: :headbang:
I ended up using tin snips and cutting the cover off, which was a right pita, and took and hour and a half! Left it off for now, will get my Indy to put a new one on. Aluminium cover with steel bolts will always rust through, a plastic cover would be far better.
Good news, no rattle. :thumbsup: :thumbsup:
I assume you do mean brake caliper and not carrier? Could you not remove the brake disc and then slide the caliper off the bolts? i.e. push the whole caliper further into the car till it disengages with the long bolt things? Once the brake disc is off you should be able to push it off. This will give you getter access to get the bolt off? After applying easing oil, etc.
