Looking for front anti-rollbar links
Marco
 Hampshire
Just checking in case someone has some front anti-rollbar links knocking about (no pun intended)..... before I go and order new ones from BMW?
Or perhaps someone could recommend some place other than BMW to get them from?
Thanks,
Marco
These are the bad boys you want...
http://www.ebay.co.uk/itm/BMW-Z4-Z-SERIES-E85-FRONT-ANTIROLL-BAR-DROP-LINK-MEYLE-HEAVY-DUTY-HD-2003-2007-/180755001649?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a15d67131
Very easy to fit on the front... if you get rears, they are more of a nightmare to change (Cut the oldies off.. wedge the newbies on)
Thanks chaps, those ebay ones look good to me. Going to try do them myself Jembo, more out of trouble in trying to find anyone willing (and honest) to do them than than anything else! :wink:
I also need to do the rear Springs (one has cracked) so I'm looking for a set of those too!
I did the fronts myself using these ones and are uprated OEM quality... some you have to angle grind off, others if u get the correct spanner & socket can get them off
As for the rear springs, if you take off the wheel, lower the axle onto a block U can undo the shock absorber... raise the car & there's enough space to get them replaced
Thanks Jembo! Did these Links come with the necessary bolts/nuts? Also, where did you get your Springs from when you replaced them?
Front drop links come with all nice shiney new bolts - rears u use your old bolts
As for springs, when I was replacing my shocks saw how easy it was to pull them out, as my spring were done shortly before I bought the car. Cheers
