Looking for advice!
Paul345
Hi. I'm currently looking to buy a 2006 Z4 2.5 si sport manual with 90000 miles. Is there any issues that i need to look out for? It has a full service history and it had a new timing chain and both vanos replaced a few years ago. Thanks
Hello.
On that mileage it is about ready for a new electric water pump. A bill just over £300 if you DIY. Significantly more if a garage does it.
Two members that I know of Bigwinn ((Stuart) and enuff zed (Martin) are really knowledgeable about these cars and know what to look out for. I am sure there are lots of others too who will pitch in. Stuart gave me a huge amount of help when I bought an E85 Z. You could try sending them private messages.
Welcome to the forum Paul. :thumbsup:
Apart from all the usual things you'd look for on a car that age it's worth checking for possible oil leaks from the cam-cover, oil filter housing and sump gaskets. Rear brake pipes can suffer from corrosion but may be tricky to check. Make sure the roof motor works properly, and if it has been relocated to the boot that's a bonus as they tend to get drowned where BMW put them.
The electric water pumps do fail at some point (generally 60K+) so if it has already had one that's another plus as they're about £300 (or £500+ from BMW).
Mileage isn't a problem with these N52 engines. I had an E91 325i with the same engine that had full BMWSH and it was still running fine when I sold it on 139K miles.
Thanks for the replys. It's had a new motor recently but not relocated. Has a advisory for a front to rear brake pipe. Will check for oil leaks and the water pump.
I’d consider getting that roof motor relocated while it’s still new and working well. Few of us on here can help with that.
What sort of cost would that be? I'm in Glasgow.
There are a few people on here who will relocate roof motors for sensible money. I'm note sure who is nearest to you in Scotland though. There used to be a guy called Durham Dave who did them but I'm not sure if he still does. Someone probably knows though!
My 2nd 2006 Z4 had advisories for rear brake pipes in 2016 and 2017. They were corroded in front of the passenger side rear wheel where the plastic cover ends, road dirt builds up and it soaks up moisture.
So later that year I got them replaced in Kunifer as the steel pipes from BMW will rust again, and being pre-formed to get the driver's side one across the rear bulkhead involves dropping the fuel tank. Kunifer can be poked through the supports with the tank in place then shaped afterwards, so despite being a longer lasting solution it was also a cheaper option.
Closest to you that I know and can recommend would be ‘Street’ who is in Newcastle.
Paul345 said:
I also read somewhere,not sure if it was about the n52 engine. Fuel injector problems?
No, that was probably the N54 engine fitted in E89s.
Thanks, will look them up.
The N52 is rock solid. You can expect the DISA and VANOS solenoids to require a bit of attention, but there’s no reason normally for the timing chain to need replacing. You should find out why, as it might be a sign of other problems.
Also, get in behind the seats and feel through the gap in the carpet for any signs of wetness in the underlay/insulation. This causes failure of the yaw sensor under the drivers seat and general condensation issues; normally as a result of failed door membranes or poorly fitting roof to window interface.
Also, get in behind the seats and feel through the gap in the carpet for any signs of wetness in the underlay/insulation. This causes failure of the yaw sensor under the drivers seat and general condensation issues; normally as a result of failed door membranes or poorly fitting roof to window interface. On the invoice it said that they carried out a code scan and found a code for crank and correlation fault. Strip engine and check timing. Timing out and chain stretched. If this normal wear and tear?
On the invoice it's said that they carried out a code scan and found a crank and correlation fault. Strip engine and check timing. Timing out and chain stretched. Is this normal wear and tear for a car that has a full service history?
That sounds unusual for the N52 engine, although I have seen a couple of E9* 325is for sale as Spares or Repairs with cam-chain problems.
My personal experiences with four N52s haven't identified any cam-chain issues, but having had it replaced must surely be a good thing for that one?
I agree with you! The whole job cost £2400.00. All main dealer parts.
And it was only done 6000 miles ago.
